how i can convert the basic langauge programming into hex file?
hiiii i have a project based on microcontroler 89c51. I have source code written in basic langauge how can i conver it into hex file and download it to 89c51? please help me it is urgent........thanks in advance
  • "... source code written in basic ...
    ... it is urgent ..."
    Does Keil vend BASIC tools?
    No?
    Then you urgently need to seek assistance elsewhere.
  • Hallo Mr. Mistry,
    did find any solution for the convertion from basic to hex?. I am very intrested becose I can write a Technical Programm in Basic verywell but C or Asm no tand so I can only make projects with vwey expansive Chips which has an Basic interpreter on Chip. If you havw found any solution Please let it me Know.
    Thanks and have a good Day
    Willy
    PS: the Cips i will programme named PIC12F683
    with the software WinPIC800 v. 3.63
  • As already noted, Keil does not have any BASIC tools - so you are in the wrong forum.
    Keil also do not support any PICs - so you're doubly off-topic!
    "any solution for the convertion from basic to hex"
    The tool to do this is called a BASIC Compiler.
    "I can write a Technical Programm in Basic very well but C ... no tand"
    A competent programmer in any high-level language shouldn't have much trouble in adapting to a new HLL - and there is a vast wealth of materials on 'C'
    eg, http://www.keil.com/books/genbooks.asp
    As you must now have noticed, "speaking" only BASIC will severely limit you - it would certainly be well worth your while to learn 'C'!
