Im using the RTX51 Tiny RTOS Ok, here is my problem. Ive been pulling my fair out trying to figure this out. I have a program that recieves 2 bytes from the uart, and sends a 5 byte word back as a responce. The software recieves a command terminated with 0x0d. The command bytes are stuffed into a ring buffer, then copied to a temp buffer from the ring buffer. In the buffer two bytes are converted into a single 1 byte command terminated with a 'CR', ie '0' '2' "CR" becomes 0x02, 0x0d.
Everything seems to work fine if i set a breakpoint in the program. Every time i send '0''2''CR' i get an answer. If i clear the breakpoint, and let the program free run, it responds the first time. The second time nothing. Stoping the program shows my temp buffer filled with 0xFF. In my ascii conversion routiene i use toint(), i know this will give a FF for a value it dose not like. I have no idea why it will work with a breakpoint every time, but allowed to run free only once.
The relevant parts of the code would be helpful.
Im doing this from work i cant just put up the code. Its on a computer with no network access. My network PC is locked from using disk/usb drives. So i cant get the code from one to another easily. I have a way, but it might take a day.
sounds like a timing issue?
what happens if you put a (long) delay at the place where you set the breakpoint?
I will try, i was under the imrpession that hitting a breakpoint causees everything to hault, essentially "stopping time" on the uP and then allowing time to start again after hitting "run".
Are some things actually still running when a breakpoint occurs?
That depends on the processor.
What processor are you using?
this is a sillicon labs c8051f120 uP
