Absolute positioning unexplain behavior
I am working with the Realview linker. The source of the issue is likely to be documented but I cannot find it - maybe you can help me.
when I'm using the following scatter file:
  ER_IROM1 0x28000 0x56000  {  ; load address = execution address
   *.o (RESET, +First)
   *(InRoot$$Sections)
   .ANY (+RO)
absolute positioning of a key in flash, at an offset of 0xFF0 from the beginning of the exection region works fine. But, if I change my scatter file to this:
LR_IROM1 0x28000 0x56000  {    ; load region size_region
   *.o (RESET, +First)
   *(InRoot$$Sections)
   .ANY (+RO)
  SOFTWARE_EVENT 0x35000  {      ; this region is used to export the software event function for quick invocation
                                                          by the firmware in case of a failure
        SOFTWARE_EVENT.o (+RO)
  ER_IROM2 0x35400 0x48C00  {  ; load address = execution address
   .ANY (+RO)
hence I absolutely position a section at 0x35000, the flash key is placed at about 0xAD00 from the beginning instead!
the scatter file shows the right address for the key, but looking at the generated binary reveals the problem.
What is happening here?
  • oops:
    I meant to say: "the map file shows the right address for the key, but looking at the generated binary reveals the problem."
    and the required offset is actually 0xFFF0.
  • Hi Tamir
    The regions SOFTWARE_EVENT and ER_IROM2 share addresses with ER_IROM1. This might confuse the linker. Are you not getting any warnings?
    Regards
    Marcus
    http://www.doulos.com/arm/
  • Marcus,
    Sorry for the confusion.
    It should have been
    ER_IROM1 0x28000 0xD000  {  ; load address = execution address
    (I did not undo enough).
    I found that if I position my code at the end of the flash (maybe the fact that it is after the key matters?), it works:
      ER_IROM1 0x28000 0x55C00  {  ; load address = execution address
       *.o (RESET, +First)
       *(InRoot$$Sections)
       .ANY (+RO)
      SOFTWARE_EVENT 0x6DC00 FIXED 0x140 {   ; this region is used to export the software event function for quick invocation
                                                             ; by the firmware in case of a failure
    but this increases my flash time...
  • this seems to work:
      ER_IROM1 0x28000 0x10000  {  ; load address = execution address
       *.o (RESET, +First)
       *(InRoot$$Sections)
       .ANY (+RO)
      SOFTWARE_EVENT 0x38000 FIXED 0x140 {   ; this region is used to export the software event function for quick invocation
      ER_IROM2 0x38140 FIXED  {  ; load address = execution address
       .ANY (+RO)
    the bootloader updates the last 16 bytes starting at 0x37FF0 when program update succeeds. I still wonder why the previous attempt went wrong!
  • Marcus,
    Can you/anybody explain the following phenomenon?
    This scatter file
       *.o (RESET, +First)
       *(InRoot$$Sections)
       .ANY (+RO)
      SOFTWARE_EVENT 0x38000 FIXED 0x60 {    ; this region is used to export the software event function for quick invocation
      ER_IROM2 0x38060 FIXED  {  ; load address = execution address
       .ANY (+RO)
    Creates a huge hole in my flash:
        RESET                                    0x00028000   Section      380  lpc2400.o(RESET)
        Undef_Handler                            0x00028040   ARM Code       4  lpc2400.o(RESET)
        PAbt_Handler                             0x00028044   ARM Code       4  lpc2400.o(RESET)
        DAbt_Handler                             0x00028048   ARM Code       4  lpc2400.o(RESET)
        IRQ_Handler                              0x0002804c   ARM Code       4  lpc2400.o(RESET)
        FIQ_Handler                              0x00028050   ARM Code       4  lpc2400.o(RESET)
        !!!main                                  0x0002817c   Section        8  __main.o(!!!main)
        !!!scatter                               0x00028184   Section       60  __scatter.o(!!!scatter)
        !!dczerorl                               0x000281c0   Section       68  __dczerorl.o(!!dczerorl)
        !!handler_zi                             0x00028204   Section       44  __scatter_zi.o(!!handler_zi)
        .ARM.__AT_0x00030010                     0x00030010   Section       16  sys_version.o(.ARM.__AT_0x00030010)
        .ARM.__AT_0x00030020                     0x00030020   Section       16  sys_version.o(.ARM.__AT_0x00030020)
        .ARM.__AT_0x00030030                     0x00030030   Section       16  sys_version.o(.ARM.__AT_0x00030030)
        .ARM.__AT_0x00030040                     0x00030040   Section       16  sys_version.o(.ARM.__AT_0x00030040)
        .ARM.__AT_0x00037FF0                     0x00037ff0   Section       16  sys_version.o(.ARM.__AT_0x00037FF0)
    Why aren't the regions 0x28204 to 0x30010 and 0x30040 to 0x37FF0 used?
    How can I coax the linker to fill there regions?
    sys_version.o contains variables that are absolutely located.
  • of course I can force the linker by doing something like this:
      ER_IROM1 0x28000 0x8000  {  ; load address = execution address
       *.o (RESET, +First)
       *(InRoot$$Sections)
       .ANY (+RO)
      ER_IROM3 0x30000 0x8000  {  ; load address = execution address
            SYSTEM_TIMER.o
       .ANY (+RO)
       .ANY (+RO)
    But I has hoped that the linker would clever enough (or me less dumb :-) )
  • Found it. This scatter file seems to handle it better:
      ER_IROM1 0x28000 0x1000  {  ; load address = execution address
       *.o (RESET, +First)
       *(InRoot$$Sections)
       .ANY (+RO)
      SOFTWARE_EVENT 0x29000 FIXED 0x60 {    ; this region is used to export the software event function for quick invocation
      ER_IROM2 0x29060 0X54FA0  {  ; load address = execution address
       .ANY (+RO)
    I'm still not sure why...the only difference is that the section SOFTWARE_EVENT is now located before the absolutely positioned stuff.
