im tryin to see the header with cout in. i looked in keil and c51 and uv3.
i can not see it? wear is it?
You are assuming that C51 supports C++. It does not.
Where did you read that C51 is a C++ compiler?
Hint: it isn't.
thx 4 yr help :::::: NOT
i know it isnot c plus plus
i found cout in the other proj file like this
char cout;
Good attempt at a save.
But note that you did not just mention the symbol name "cout" - your subject line also specified "clases" [sic!] which do imply an interest in C++ objects. C does not have any classes or objects.
This joke is not very amusing. Boring, perhaps...
not very amusing, boring ???
No. Shows programmers do have a sense of humor.
Question is whether that sense has any worth!!??
