I'm currently writing a series of unit tests for a module which is included within our embedded firmware. There is a high possibility that this module will evolve so these tests will need to be re-run. I'm running the unit tests within the simulator and was hoping to be able to hit run, the tests get executed and once complete the results get outputted to a file so that I have the necessary evidence that the tests have been carried since I'd rather not have to sit and manually copy out the test case results. I've had a look at the C51 manual and it says that fopen isn't supported. Is there an alternative solution to logging my test results?
Cheers for any help that is forth coming.
Capturing debug output on the serial port?
Yes if this can be emulated using the simulator debug session as I don't have any hardware at present. Even if I did I don't have a serial port available to me on the intended hardware.
The code that I'm testing is the algorithmic / functionality side of things rather than the hardware abstraction layer and in an ideal world I'd use Visual Studio or the like which would allow me to write data to a file, but the test cases need to be written in Keil so that I don't have to worry about the differences between the compilers...endinness, data types etc.
At present I'm placing a breakpoint at the end of the last test and selecting run. When the simulator hits the breakpoint, I then have to observe the results (values returned from the test case functions) via a watch window and copy them over into a spread sheet/csv file for the records. Being able to have Keil to automate this transfer of results into a file would save me no end of time, avoid finger troubles and let me get on with coding.
The debugger can capture the serial port data from the simulated processor.
If your processor has a serial port, and you haven't configured the processor to allocate the relevant pins or baudrate timer for other tasks, then it doesn't matter that your target hardware does not have a serial port.
On the other hand - if your test code does not depend on any hardware resource that collides with the UART function, then you can reconfigure your simulated processor to have a serial port just for these tests.
