Float and union Storing in EEPROM
Hi, i've tried to store a float variable into eeprom and i couldnt achieve it , when i printf it outputs NNDD ! strange thing , however it works fine with integers
 typedef union {
    unsigned char array[sizeof(float)];
    float gain;
} ahmed;
ahmed temp;
// to save value
           EDATA1=temp.array[0];          //put 78 in edata 0   //GN0L
           EDATA2=temp.array[1];          //put 51 in edata 1   //GN0M
           EDATA3=temp.array[2];          //put 2 in edata 2    //GN0H
       EDATA3=temp.array[3];
// to retrive value
            temp.array[0]=EDATA1;
           temp.array[1]=EDATA2;
           temp.array[2]=EDATA3;
           temp.array[3]=EDATA4;
// to print value
        printf("%1.0f",(float)temp.gain);                    //Output result to UART
  • What does it do if you just load the values into the array, and then print the float?
    ie, if you take the EEPROM out of the equation, does it work?
  • Take a closer look at your indices:
    A float is four bytes large. You make two assigns to EDATA3. And why have you only commented 3/4 of the lines?
  • Sorry about the typo in the above code , by the way its worked when printing the float , but it doesnt save it into the eeprom , however it does save integers
     void Save_Gain(void)
    {                       //First byte of gain (GN0L).
               EADRH=0x00;    //set page address at 00h  high byte (03ff)
               EADRL=0x00;    //low byte
           EDATA4=temp.array[3];
               ECON=0x05;     //erase page
               ECON=0x02;     //write EDATA1-4 into pre-erased
               ECON=0x04;     //verify page
           HW_Delay(50);
    void Get_Gain(void)
           ECON=0x01;      /*read current 4byte page of FlashEE
                                    //into EDATA1,2,3,4*/
               //HW_Dalay(20);
    //       GN0H=EDATA3;                     //put saved value in gain register H
               //GN0H=255;
               //HW_Dalay(20);
    //       GN0M=EDATA2;                     //put saved value in gain register M
             // GN0M=255;
               //HW_Dalay(20);
       temp.array[0]=EDATA1;                           //put saved value in gain register L
            // GN0L=255;
               //HW_Dalay(20);
