Dear friends, is there any 1 who implemented the Flash file system for LPC2366 RAM / SPI flash.
I have coded the RAM flash driver as per RL_FLASH FS help page info.
finit() and fformat() is ok; but i am not able to open a file in write mode also.
on some forum pepl recomending to increase HEAP and STACK size.
I have stack size 0x00000050 ( user ) heap size 0x00000800
thans for any suggetions
regarding the above problem; I am implementing the Flash_fs for onchip ram; main()------ FILE *fin; FILE *fout; char test[5]; int test1,test2; PINSEL0 |= UART0TX; PINSEL0 |= UART0RX; InitSerial( 0, 57600, 0, 3, 0 ); U0sendchar('Y'); while(1) {test1 = finit(); U0sendchar(test1 + 1); test1 = fformat("R:"); U0sendchar(test1 + 2); // Open a file on the RAM Drive fin = fopen ( "report.txt", "w" ); if (fin == NULL) {U0sendchar('A');} else { fwrite ("UTS", sizeof (char), 3, fin); fclose (fin); U0sendchar('Y');} ---------------------------------------- I have --> // #pragma(__use_no_swi.....) in retarget.c on entry to fwrite() exicution goes to SWI handler and gets reset. if above comment sign removed gives linker ( library) error-----
ram_test.axf: Error: L6915E: Library reports error: __use_no_semihosting_swi was requested, but a semihosting fputc was linked in **************************************************** if any 1 have implemented RAM file system please help. thanks,
udit
