Debugging XE164 with changed DBGPRR
(c166v617 demo)
I designed a XE164 board, where there was the need of changing some pins of the default JTAG-Debuginterface, but I can't connect to it with Infineon DAS-Client and 'JTAG over USB Chip'.
My first try was rewirering the default JTAG-pins by hand. Now everything runs as expected (flashing and debugging). So I removed the hand wires again.
I rewrite the ESFR DBGPRR (EINIT-protected) in the very top of the Startup-file
DBGPRR    DEFR   0F06EH
EXTR    #01H
MOV     DBGPRR,#0x0148
and programmed my appl. into Flash using Memtool. But can't still connect. (Error: Target DLL has been cancelled. Debugger aborted)
I think the problem is, that the Keil debugger always issues a Reset when connecting to the XE164. Is there a way to skip this? Maybe I overlook something in the settings...
(btw. there is at least one other Debugger which provides the ability to connect without a reset)
