my answer
Hello, I'am very happy to answer your question! I come from China, Guilin Institute of University.
this is my answer:
1. writting your source code
2. compile your project. Notethat: when you select "translate current file" button, you will get a messsage: error 56 cannt open file. But if you select other two buttons,"translate modified files and build application" or "re-translate all source files and build application" button, there are no errors when "debug" buttong is pressed.
may you success!
