memory missmatch if I want to debug
at the moment, I'm working with the S29AL032D flash device (together with an AT91SAM9260); I'm able to write code to the flash and the processor is able to start the code.
If I download some code to the flash then I'm able to debug the code with keil (but only once). If I try to debug the code a second time - I get always the error message "memory missmatch".
docs-europe.electrocomponents.com/.../0900766b80a27c29.pdf
I'm not sure what this problem will cause....
best regards
Jörg
