Problem when reading internal flash via pointer, EXTS
I use a XC164CS32F40-Controller and C166 V05.05:
I want to read the data of the internal flash via following code. It works correct until the adress 0xC13518 will be reached.
The Assembler-Cmd "EXTS R5,#1" jumps to Adress 0xC00002A. I checked it via Debugging with ULINK. Normally he jumps to adress 0x00C00178.
This is a reduced routine of a CRC-calculation of the internal flash-memory.
void main ()
   unsigned char xhuge* pByte;
   unsigned char u8Val;
   pByte  = (unsigned char xhuge*)0x00000000;
   while (1)
      u8Val = *pByte;
      pByte++;
=> in Assembler:
u8Val = *pByte;
   00C0016E D4500200  MOV      R5,[R0+#0x0002]
   00C00172 A840      MOV      R4,[R0]
   00C00174 DC05      EXTS     R5,#1
   00C00176 A984      MOVB     RL4,[R4]
   00C00178 E4800400  MOVB     [R0+#0x0004],RL4
