hello,
I have to use the cctalk protocol with the SAB80C535 (8051 family).
before to begin to write the code for using this protocol, I would like to know if someone know if is it possible to dowload the source code of this protocol in ANSI C for using it in µvision?
or if someone has alredy use it?
tanks for your help.
http://www.cctalk.org/
en.wikipedia.org/.../CcTalk
Why do you want the code in ANSI C, and not just in the programming language C?
Note that the protocol handler will be quite close to the hardware, so it isn't unlikely that your own implementation will not be 100% ANSI or ISO.
A more important criteria if asking for code is to request tested and/or well-documented code and to add criterias for allowed licensing terms.
If the code is tested and well-documented, then it is probably in a good enough state that you can modify it for your hardware - possibly removing some non-ISO keywords and possibly adding some other non-ISO keywords.
