Hello, Is there any way to initialize, define and use all the variables in external EEPROM instead of external RAM in C.
The device i am using is AT89C5131 and i want to use 1K EEPROM insted of 1K RAM internal expanded inside the controller.
Is it a serial EEPROM, or a parallel EEPROM?
It is inbuilt inside the controller chip (and can be accessed through MOVX instruction in assembly as for internal expanded 1kB RAM).
It can be used with the MOVX command for writing?
So why did you call it "external" if it is internal?!
Sorry for my mistake Mr. Neil, but according to datasheet the inbuilt 1k RAM and EEPROM can be accessed through MOVX instruction which is same for accessing external RAM or memory.
But, I want to know how should I use this EEPROM for initializing, defining and using the variables and constants in C code, as all variables by default stores in RAM only by C compiler, how can i configure compiler to use EEPROM instead of the RAM. If there is any way please suggest me.
Thanks.
Yes, you can get the compiler to do it by using the FAR data support.
Or you can just do it the "traditional" way by writing your own access functions.
See http://www.keil.com/forum/docs/thread5635.asp and follow all the links!
