Hi any one please tell me how to calculate tne time delay in keil c program usink keil ide
hi
when you write routine for delay to check its delay there is menu: 1.view:performance analyser window under that include your function name and debug it 2.view:logic analyser window in delay if you toggle a port pin then above menu is also useful which will give you waveform
byte take care
Thanks rose
but that is being not the caluculation!!!!!
it is seeing how long code is be take you be knowing.
you if changed optimizatien, you will being change timing in normallly way.
kalib rahib: you are the man! OP: how about using a hardware timer...?
please any one tell me for loop takes howmany machine ion in
There is absolutely no way whatsoever to predict in advance how many machine cycles will be required by any high-level source construct.
This is fundamental to the whole idea of high-level languages!
You can examine or measure the generated machine code after compilation - but you cannot predict it before compilation.
And you cannot guarantee that it will remain the same after subsequent compilations - even if you don't change any compiler settings!
Therefore, if you really need to know, do it in assembler!
See: www.8052.com/.../149030
exept if you being the compiller ;) ;) ;)
In which case, you wouldn't need to ask the question!
