I want to measure the bandwidth of the usb 2.0. I have a board with cypress Fx2 and FPGA. I have developed the firm ware in keil C.Should I code something in Keil C to measure the bandwidth delivered by USB or how can I do it ? thanks punitha
Do you mean you want to measure the actual throughput of the setup? Then, hook a frequency counter or a digital scope with frequency function to the strobe signal of the FX2-FPGA interface. It should flip every byte (or word) transfer.
You may be able to built in similar function on the FPGA, and read it over JTAG - like Xilinx chip scope.
Of cource, you may be able to write a code for the FX2 core, but I'm not sure I can explain it for you easy enough :-)
Tsuneo
Thanks ,
I have already measured the burst rate ( FX2 to FPGA).Now I want to measure speed from PC to board with my firmware and FPGA? Any idea of how to do it ?
How about USB benchmark utility on PC? - USB Info - The original website seems to disappear - USB Performance Software www.usbperformance.com/.../
etc.
Software sniffers also have transfer statistics.
If you want to measure the traffic on the bus, a hardware bus analyzer is required.
thanks
There was a program in cypress "Bandwidth meter " to the test the speed of the PC and USB. I tried it and i was able to achieve 45MB/s as peak bandwidth. But it did not involve my firmware or the FPGA. It was just to test the speed of PC. but will i get the same bandwidth when I use my firmware to transfer data? . The program in the cypress does not transfer data to th outside world.
Unless there is any packet loss, the throughput performance is the same, regardless of the place where you attach a prove, though there may be temporarily fluctuation absorbed by buffers.
Or do you want to detect packet loss?
thanks. I just want to test the performance of the USB
