Hello, I program a code to write and read the flash memory in my MCU (C8051F020) in C ? The writing is ok but not the reading. After reading, i send the value by UART. This function isn't ok. can i help me ?
//----------------------------------------------------------------------------- // Includes //----------------------------------------------------------------------------- #include "C8051F020.h" // SFR declarations #include "stdio.h" //----------------------------------------------------------------------------- // 16-bit SFR Definitions for 'F02x //----------------------------------------------------------------------------- sfr16 DP = 0x82; // data pointer sfr16 TMR3RL = 0x92; // Timer3 reload value sfr16 TMR3 = 0x94; // Timer3 counter sfr16 ADC0 = 0xbe; // ADC0 data sfr16 ADC0GT = 0xc4; // ADC0 greater than window sfr16 ADC0LT = 0xc6; // ADC0 less than window sfr16 RCAP2 = 0xca; // Timer2 capture/reload sfr16 T2 = 0xcc; // Timer2 sfr16 RCAP4 = 0xe4; // Timer4 capture/reload sfr16 T4 = 0xf4; // Timer4 sfr16 DAC0 = 0xd2; // DAC0 data sfr16 DAC1 = 0xd5; // DAC1 data //----------------------------------------------------------------------------- // Global CONSTANTS //----------------------------------------------------------------------------- #define SYSCLK 22118400 // SYSCLK frequency in Hz #define BAUDRATE 115200 // Baud rate of UART in bps sbit LED = P1^6; // LED='1' means ON //----------------------------------------------------------------------------- // Function PROTOTYPES //----------------------------------------------------------------------------- void SYSCLK_Init (void); void PORT_Init (void); void UART0_Init (void); void Timer0_ms (unsigned ms); //unsigned char EE_Read (unsigned Addr); //void EE_Write (unsigned Addr, unsigned char value); //----------------------------------------------------------------------------- // Global VARIABLES //----------------------------------------------------------------------------- char eedata [6]; unsigned int ii; //----------------------------------------------------------------------------- // MAIN Routine //----------------------------------------------------------------------------- void main (void) { unsigned char xdata * idata pwrite; // pointer to FLASH used for writes // NOTE: this pointer must be located // in <data> or <idata> space! unsigned char code *pread; // pointer to FLASH used for reads char EA_save; // saves the current state of the // interrupt enable bit. // test string stored in FLASH unsigned char code test_string[] = "Howdy!"; // disable watchdog timer WDTCN = 0xde; WDTCN = 0xad; SYSCLK_Init (); // initialize oscillator PORT_Init (); // initialize crossbar and GPIO UART0_Init (); // initialize UART0 // PART A -- erase the FLASH page at 0x1000 // initialize write/erase pointer pwrite = (unsigned char xdata *) 0x1000; EA_save = EA; // save interrupt status EA = 0; // disable interrupts (precautionary) FLSCL |= 0x01; // enable FLASH writes/erases from // user software PSCTL = 0x03; // MOVX writes erase FLASH page *pwrite = 0; // initiate page erase PSCTL = 0; // MOVX writes target XRAM FLSCL &= ~0x01; // disable FLASH writes/erases from // user software EA = EA_save; // re-enable interrupts // PART B -- copy test string to FLASH memory at address 0x1000 // initialize FLASH read pointer pread = (unsigned char code *) test_string; EA_save = EA; // save interrupt status EA = 0; // disable interrupts (precautionary) pwrite = 0x1000; // initialize FLASH write pointer FLSCL |= 0x01; // enable FLASH writes/erases from // user software PSCTL = 0x01; // MOVX writes target FLASH memory while (*pread != '\0') { // copy until NULL is detected *pwrite = *pread; // copy byte pread++; // advance pointers pwrite++; } *pwrite = '\0'; PSCTL = 0x00; // MOVX writes target XRAM FLSCL &= ~0x01; // disable FLASH writes/erases from // user software EA = EA_save; // re-enable interrupts // PART C -- read test string to FLASH memory at address 0x1000 and copy in tab eedata EA_save = EA; EA = 0; pwrite = 0x1000; FLSCL |= 0x40; PSCTL = 0x00; while (*pread !='\0') { *eedata = *pread; // copy byte pread++; // advance pointers pwrite++; } PSCTL = 0x00; // MOVX writes target XRAM FLSCL &= ~0x40; // disable FLASH writes/erases from // user software EA = EA_save; // re-enable interrupts while (1) // spin forever { for (ii=0;ii<6; ii++) { LED = 1; printf("%c",eedata[ii]); printf("@13"); } printf("\x0d"); printf("\x0a"); LED = 0; } }
thanks
Regards
Cross-posted here: www.8052.com/.../read.phtml
Any more cross-postings?
Sorry for Cross-posted. I thought the forums were independent.
regards
"I thought the forums were independent."
But they are. That is why it is so bad that you cross-post.
You are trying to get two independent groups of people to work at the same time solving the same problem. And one group will not be able to know what progress the other gorup does.
So you are basically stealing time from a lot of people by having people run around and doing redundant work.
It is similar to sending an email to sevaral different teachers at school and ask the same question. Since they will not know that you have asked multiple times, you have wasted the time of at least one teacher, when he/she spends time on a problem you have already received a solution for.
In short: You are implying that your time and your needs are so very much more worth than the time of all other people on the forums that it really doesn't matter how many hours of work you dish out redundantly.
Help on forums are limited resources, so don't ask for more help than you need, or people will decide to ignore you.
when cross-posting state that yo are doing so in tour posts
.... He crossposted, this time on the SILabs forun once more without having the courtesy to mention the crossposts.
Might be because he got tired of not answering my questions about how a read loop would work if the code doesn't initialize the read addreess pointer before starting to loop.
Or what happens if *pread points to a null character before the first while() test.
He might also have become tired of not answering how he manages to store a string of six characters into the first byte of an array by always writing to *eedata aka eedata[0].
Most probably, he doesn't want comments about problems in the code - he want rewritten code...
My problem is resolved. See 8052 forum : www.8052.com/.../159624.
I guess cross-posting rocks, after all...! Live long and prosper :-)
Thank you for posting the update - well done, you're learning!
Umfortunately, the link is broken - probably due to the recent update of 8052.com... Try this instead:
www.8052.com/.../159724
Note that it would be helpful if you would explain exactly how you fixed it, for the benefit of others who may be following this...
Actually he appended a '.' at the end of the URL he gave which is why it was broken. Other than that ... glad he had his resolution.
Stephen
