I have MCB2300 EVB and use Keil ARM uVision 3.2. I need help on USBHID : - Change data tranfer in/out to more bytes (16,32,64,.. bytes). - Just send data when I want only(in the example data has been sent continuosly ?) Thanks very much.
Start by searching for posts made by Tsuneo Chinzei on this forum. They should contain all the required information.
Thanks for your help. I have modified USBHID to read/write 64 bytes of data. And I also midify HID_Client (Visual C++ 6) to work with this modified example. Here is link to download : www.megaupload.com/
USBHID example and HID_Client_VC6 update www.megaupload.com/
USBHID example and HID_Client_VC6 update Link rapidshare (same as " href= "http://rapidshare.com/files/155087461/USBHID.zip.html">rapidshare.com/.../USBHID.zip.html
