what is the use of default in switch-case?
It is similar to tht 'else' in an 'if' statement. Something to do if no specific alternative matches.
Don't you have a good C book to read? If not: Do get one!
to catch coding mistakes with few exceptions, if default: get entered you have made a mistake
Entering the default clause in a state machine (where the switch variable is normally an enumerator) should preferably be coded to represent an error.
But a switch statement is used for way more than just state machines.
When decoding charactesr in a parser, you may have:
switch (ch) { case '(': do_lparen(); break; case ')': do_rparen(); break; case '+': do_add(); break; ... default: if (ch >= 'a' && ch <= 'z' || ch >= 'A' && ch <= 'Z') { do_alpha(ch); } else if (ch >= '0' && ch <= '9') { do_digit(ch); } else { invalid_character(ch); } }
