CAPCOM Timers don'
Hello All,
I am a newbie to the XC164CS and am trying to get the capcom timers to run and interupt on overflow. I used DAVE to generate code and checked it with the uC datasheet. It looks like everything is setup correctly, but I get no capcom counting or interupts on overflow. Is there any special sequence of load registers etc to get them to run? Using the debugger I can see the reload registers and the config and interupt registers are set up correctly, but again no capcom timer (T0/T1) timing..Any ideas???
Thanks,
