UART DOCUMENT LPC23XX PROBLEM
Dear All,
I have tested the Equation for calculate Baud rate but I have found a problem with the example of the Manual LPC23XX Rev.1 11 March 2008 Page 433.
These are the rows that I took from MANUAL LPC23XX Rev.1:
4.17.1.2 Example 2: PCLK = 12 MHz, BR = 115200
According to the the provided algorithm DLest = PCLK/(16 x BR) = 12 MHz / (16 x 115200)
= 6.51. This DLest is not an integer number and the next step is to estimate the FR
parameter. Using an initial estimate of FRest = 1.5 a new DLest = 4 is calculated and FRest
is recalculated as FRest = 1.628. Since FRest = 1.628 is within the specified range of 1.1
and 1.9, DIVADDVAL and MULVAL values can be obtained from the attached look-up
table.
The closest value for FRest = 1.628 in the look-up Table 17â€"372 is FR = 1.625. It is
equivalent to DIVADDVAL = 5 and MULVAL = 8.
Based on these findings, the suggested UART setup would be: DLM = 0, DLL = 4,
DIVADDVAL = 5, and MULVAL = 8. According to Equation 17â€"12 UART’s is 115384. This
rate has a relative error of 0.16% from the originally specified 115200.
This is my code:
U1LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */
U1DLM = 0x0; /* Divisor Latch LSB */
U1DLL = 0x4; /* Divisor Latch MSB */
U1FDR = 0x85; /* Fractional Divider Register */
U1LCR |= 0x03; /* DLAB = 0 */
U1FCR = 0x07; /* Enable and reset TX and RX FIFO. */
Is it OK?
Michele
