Hi all,
I need to recover the remainder of a division but no matter what I try the result comes out as 1.
so far I have tried: u8 a = 10 u8 b = 3 u8 r;
r = a % b; r = fmod(a,b) res = div(a,b) r = res.rem;
Casting applied in real code removed for ease of reading. 10/3 = 3.33 clearly what I need is a way to recover the 33 etc, I expect it to be truncated but I didn't expect to get 1 or all remainders.
Compiler is realview Arm, on a STM32 cortex-m3.
Thanks, Dave
Floating point: 10 / 3 = 3.3333333 Integer: 10 / 3 = 3
10 - 3*3 = 1
So, since the reminder _is_ 1, you should stop trying to get a different reminder... ;)
In this case, you are _not_ interested in getting a reminder, you are interested in retrieving the fractional value.
Several ways go get your value:
(10 % 3) / 3.0;
fmod(10.0/3.0,1.0);
10.0/3.0 - (10/3);
10.0/3.0 - floor(10.0/3.0);
Thanks Per,
I think I need a holiday. You are of course correct and I've had a brain malfunction.
Regards, Dave
