dear friends,
i m searching any 8051 compitible IC tht has following specifications
1> proberble manufacturers --> Atmel , philips, sygnetics, paloma. 2> ISP Capability ---> very must 3> has 9 i/o ports ( means around 81 i/o lines) 5> 12 machine cycle operation as conventional 8051 is having. --> must proberbly. 6> on chip EEPROM. FLASH MEMORY. RAM. 7> for ISP, windows based software available and LINUX
all other extra.. -- no problem .
Can some one provide me the information about just the IC number having above configuration please....
thanks in advance...
RONY
Here: http://www.keil.com/dd/search_parm.asp
1> proberble manufacturers --> Atmel , philips, sygnetics, paloma. 2> ISP Capability ---> very must 3> has 9 i/o ports ( means around 81 i/o lines) 5> 12 machine cycle operation as conventional 8051 is having. --> must proberbly. 6> on chip EEPROM. FLASH MEMORY. RAM. 7> for ISP, windows based software available and LINUX ad 1) SIgnetics has not existed for years, what is paloma? ad 2) most modern chips do ad 3) the most i know of is 8 ports (8051f12x) ad 4) ??? ad 5) most modern chips do not ad 6) most modern chips do ad 7) you will have tough time to find it for Linux.
ad the above DO use the Keil search engine
