I must simulation of an audio amp using 8051. This is not the standard model but a subcircuit based one which I need made from the data sheet.
haz ne1 the cod3 for it becoze I must have it working very soon.
kan u geev e-male 4 cod3?
plz send d cod3 v quik to ppp8@hotmail.com
it is now v urg and i require the details imedi8ly
You are hardly explaining what your problem is. You should give more technical details about what you are doing and what you want to achieve. Otherwise, no one is going to be able to help you out.
From the writing, this is either a joke, or written by someone who don't know enough to give a better explanation.
Questions made the SMS way can't really be taken seriously.
... the whole idea of using an 8051 to simulate an audio amplifier must be a joke - surely...?!
It looks to be a student trying to get an easy solution to there school work. Judging from the 'L33T' speak used. Which is not only silly it's extremely rude and annoying.
Unless he is using one of the mp3 connect C51's. However that still requires a technical explanation of which none is given.
