External memory interface & Uart
Hi All,
I add the UART code into EMI example from the ST and compile the following code with the configuration Options->Target
-> off-chip RAM1 0x3c000000 size 0x400000
-> on-chip IRAM1 0x4000000 size 0x18000
The message " EMI Example ***" cannot be sent to the Hyperterminal. However, the EMI works fine.
Anyone has experiences with EMI and UART? Could you please point out where I am wrong? Greatly appreciate your help.
u8 TxBuffer[] = "EMI Example ****\n\r"
int main()
#ifdef DEBUG debug();
#endif
/*CPU running @96MHZ*/ MCLK_Config ();
/* Configure the system clocks */ SCU_Configuration();
/* Configure the GPIO ports */ GPIO_Configuration();
/* UART0 configuration -------------------------------------------------------*/ /* UART0 configured as follow: - Word Length = 7 Bits - Two Stop Bit - No parity - BaudRate = 115200 baud - Hardware flow control enabled (RTS and CTS signals) - Receive and transmit enabled - Receive and transmit FIFOs are enabled - Transmit and Receive FIFOs levels have 8 bytes depth */ UART_InitStructure.UART_WordLength = UART_WordLength_8D; UART_InitStructure.UART_StopBits = UART_StopBits_1; UART_InitStructure.UART_Parity = UART_Parity_No ; UART_InitStructure.UART_BaudRate = 115200; UART_InitStructure.UART_HardwareFlowControl = UART_HardwareFlowControl_None; UART_InitStructure.UART_Mode = UART_Mode_Tx_Rx; UART_InitStructure.UART_FIFO = UART_FIFO_Disable;
UART_DeInit(UART0); UART_Init(UART0, &UART_InitStructure);
/* Enable the UART0 */ UART_Cmd(UART0, ENABLE);
/* EMI default configuration : Reset configuration*/ EMI_DeInit();
/**************************EMI configuration*********************************/
EMI_StructInit(&EMI_InitStruct); /* Number of bus turnaround cycles added between read and write accesses.*/ EMI_InitStruct.EMI_Bank_IDCY = 0x3 ;
/* Number of wait states for read accesses*/ //EMI_InitStruct.EMI_Bank_WSTRD = 0x3 ; EMI_InitStruct.EMI_Bank_WSTRD = 0x5 ; /* Number of wait states for write accesses*/ //EMI_InitStruct.EMI_Bank_WSTWR = 0x3 ; EMI_InitStruct.EMI_Bank_WSTWR = 0x4 ;
/*Output enable assertion delay from chip select assertion*/ EMI_InitStruct.EMI_Bank_WSTROEN = 0x2;
/*Write enable assertion delay from chip select assertion*/ EMI_InitStruct.EMI_Bank_WSTWEN = 0x2;
/*This member Controls the memory width*/ EMI_InitStruct.EMI_Bank_MemWidth = EMI_Width_HalfWord;
/*Write protection feature */ EMI_InitStruct.EMI_Bank_WriteProtection = EMI_Bank_NonWriteProtect;
/*Use Bank1 (CS1)*/ EMI_Init( EMI_Bank1, &EMI_InitStruct);
/* Send a buffer from UART to hyperterminal */ while(NbrOfDataToTransfer--) { UART_SendData(UART0, TxBuffer[TxCounter++]); while(UART_GetFlagStatus(UART0, UART_FLAG_TxFIFOFull) != RESET);
while (1) {
/*Write in the external memory*/
for (k = 0; k < 32; k++)
*(u16*)(0x3C000000 + (k*2)) = Buffer_Write[k] ;
// *(u16*)(0x3C000000 + (k*2)) = 0x0101 ;
/*Read from the external memory*/
Buffer_Read[k] = *(u16*)(0x3C000000 + (k * 2)) ;
/*Comparaison*/
/* Check the received data with the send ones */ TransferStatus = Buffercmp(Buffer_Write, Buffer_Read, 32);
if (TransferStatus != 0) UART_SendData(UART0, (u8)(TransferStatus+48));
* Function Name : SCU_Configuration
* Description : Configures the system clocks.
* Input : None
* Output : None
* Return : None
void SCU_Configuration(void)
/* Enable the clock for EMI*/ SCU_AHBPeriphClockConfig(__EMI | __EMI_MEM_CLK, ENABLE);
/*BCLK=96Mhz*/ SCU_EMIBCLKDivisorConfig(SCU_EMIBCLK_Div1);
/*Enable the Mux mode*/ SCU_EMIModeConfig(SCU_EMI_MUX);
/*ALE length and polarity definition*/ SCU_EMIALEConfig(SCU_EMIALE_LEN1, SCU_EMIALE_POLHigh);
/* Enable the GPIO7 Clock */ SCU_APBPeriphClockConfig(__GPIO7 , ENABLE); SCU_APBPeriphReset(__GPIO7,DISABLE);
SCU_APBPeriphClockConfig(__UART0, ENABLE); SCU_APBPeriphReset(__UART0,DISABLE);
/* Enable the GPIO2 Clock */ SCU_APBPeriphClockConfig(__GPIO2, ENABLE); SCU_APBPeriphReset(__GPIO2,DISABLE); /* Enable the GPIO3 Clock */ SCU_APBPeriphClockConfig(__GPIO3, ENABLE); SCU_APBPeriphReset(__GPIO3,DISABLE);
/* Enable the GPIO8 Clock */ SCU_APBPeriphClockConfig(__GPIO8, ENABLE); SCU_APBPeriphReset(__GPIO8,DISABLE); /* Enable the GPIO9 Clock */ SCU_APBPeriphClockConfig(__GPIO9, ENABLE); SCU_APBPeriphReset(__GPIO9,DISABLE);
* Function Name : GPIO_Configuration
* Description : Configures the different GPIO ports.
* Input : None
* Output : None
* Return : None
void GPIO_Configuration(void)
{ /* GPIO8,GPIO9 Configuration*/
GPIO_EMIConfig(ENABLE);
/* GPIO7 Configuration */ GPIO_DeInit(GPIO7); GPIO_InitStructure.GPIO_Direction = GPIO_PinOutput;
/* GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 ; */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull; GPIO_InitStructure.GPIO_Alternate = GPIO_OutputAlt2 ; GPIO_Init (GPIO7, &GPIO_InitStructure);
//uart0 setup
GPIO_DeInit(GPIO3); /*Gonfigure UART0_Rx pin GPIO3.0*/ GPIO_InitStructure.GPIO_Direction = GPIO_PinInput; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ; GPIO_InitStructure.GPIO_IPConnected = GPIO_IPConnected_Enable; GPIO_InitStructure.GPIO_Alternate = GPIO_InputAlt1 ; GPIO_Init (GPIO3, &GPIO_InitStructure);
/* GPIO_DeInit(GPIO3); */ /*Gonfigure UART0_Tx pin GPIO3.1*/ GPIO_InitStructure.GPIO_Direction = GPIO_PinInput; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ; GPIO_InitStructure.GPIO_Alternate = GPIO_OutputAlt2 ; GPIO_Init (GPIO3, &GPIO_InitStructure);
  • Not many people can or want to read your code, since you didn't follow the instructions how to post code.
    Also - what processor are you using? Any other important information you feel should be given? Have you checked with an oscilloscope if you get any serial data? Are you running the CPU at 96MHz as one of the source comments seems to imply?
  • Sorry for my long post. I only want to give as much as more information. I use STR912FA44 and set PLL at 96 MHz. I check the oscilloscope and no data out.
  • It's not that it's long - it's that it's illegible!
    Please pay attention to the instructions for posting code - clearly given above where you typed your message:
    www.danlhenry.com/.../keil_code.png
    Note that TABs don't work (well) - use spaces instead,
    and don't forget to check it in the 'Preview'...
  • I post the code again.
    Thank you for your help.
    Lillian
    int main()
    #ifdef DEBUG
      debug();
    #endif
      MCLK_Config ();
            - Two Stop Bit
            - No parity
      UART_DeInit(UART0);
      EMI_DeInit();
      /*Use Bank1 (CS1)*/
     while (1)
        /*Comparaison*/
    * Input          : None
    * Output         : None
    * Return         : None
      /*BCLK=96Mhz*/
    * Input          : None
    * Output         : None
    * Return         : None
      GPIO_DeInit(GPIO7);
    //uart0 setup
      GPIO_DeInit(GPIO3);
