print hello on serial with mcb2140
I am having mcb2140 arm7 board.
I have 2 questions:
1)When i try to run the program(which prints hello on the serial window) throgh ulink arm debugger,I cannot see any output.But when i run the same program through simulator it works fine.Is mcb2140 board not able to print some text on serial window???
2)I made a small program which switches the led on and off.It runs fine with the debugger.But how tho make this code automatically run when i reset the board.
Please give your valuable suggestions
thanks
