Hi, all KEIL users!!
Perhaps, are there manufactured goods by using RTX?
If so, please let me know the cases.
Thanks.
David.
could you please explain what you mean?
Yes, there are manufactured goods using the RTX.
People would not buy commercial licenses of the Keil tools unless they expect the tools to be used. Especially the companies who buy the RL-ARM kit to get the source code to RTX.
On the other hand, not too many companies are interested in talking about their tools, software designs etc, so you may not get too many explicit examples.
You also won't normally see something like "RTOS inside" on a product.
hmm. Why is the english so fractured by so many people here?
The answer to your question is, Yes there are many of them.
I wrote a program using RTX-51 back in like 90 or 91. It was a 12 mhz 8051 (fastest one around was a Dallas part at 20 mhz) and I could not get the company to use it. I *DID* prevail and forced the hardware guy to put a 32K sram on the board.
This product controlled 4 DUARTS. I used 8 tasks uner RTX-51 to handle the UARTS. There was also a timer task, and several other tasks. It worked well, though it was hard-pressed to keep up with 8 uarts running 9600 baud, decode the X.28 protocol on each one and do it right.
RTX-51 worked very well. I still have a copy of it, but don't have the manuals anymore, so have never used it for anything since.
This box was a communication concentrator for a system of stop light controllers.
Well maybe because this forum is a haven for people from all over the world? Some of us here seem to have similar problems with posting source code correctly. Here is an example: http://www.keil.com/forum/docs/thread13051.asp
Not to mention the inherent inability to narrow down the problem to something comprehensible...!
