Hello I need to do the ultrasonic washer. How I can make the transducer ultrasonic o what trasnsducer i can used.
Thansk for your cooperation.
Is the ultrasonic washer some sort of dance?
What has this got to do with the Keil toolset?
Anyhows ... Don't bother making the ultrasonic transducer, just search the Internet and find a supplier of them.
Use some dilithium crystals and shift the resonance phase but make sure the flux capacitor doesn't overload.
you fool! that will only bring you to warp 3!
you be wanting a ansewr for the 51 yes.
you must waiting for sir erac for the giving of ansewrs
he be thinking he knowes the 51 and sometimes gives a ansewr to be good and corrrect. sometime.
but he be sleeeps like a bare {verry verry late} and is misrabel untill he gives some silly ansewrs first.
be a patient and you can be lucky with his ansewr yes????
The dilithium crystals are a little on the expensive side :(
* 5A3266E3-82B2-4DCB-8A0C-23BE1236021C thinks ordinary TNT will make the transducer supersonic.
A more interesting - but still well-documented on the web - is to build a linear accelerator aka rail gun.
it is either he is a hibernating bear, which conforms this statement:
or the good old god, reflected in these statements:
either way rahib, you can be as smart and clever and all-knowing as sir erac if you study hard and play. always play and never give up.
