Hi, I use the functions coming with µVision for ARM.
example out of lib_AT91SAM9260.h:
__inline void AT91F_PIO_SetOutput( AT91PS_PIO pPio, // \arg pointer to a PIO controller unsigned int flag) // \arg output to be set { pPio->PIO_SODR = flag; }
The problem is, that under some circumstances the register is not set. If I set the register "by hand" inside the memory view it works. And if I use
AT91C_BASE_PIOC->PIO_SODR = flag
it works in most cases. In all cases
*AT91C_PIOC_SODR = flag
works.
Does someone have the same problem?
