Hi there,
Does anyone know what the error A1329W - Unpredictable instruction (forced user mode transfer with write-back to base) means? This used to be an warning and now it is an error from the assembler. I've been faced this error in LDM/STM instructions, such as:
LDMIA R0!, {R11-R12,R14}^
I've searched in the Keil documention, knowledge base and google but I hadn't success.
Thank you, Wander.
Found: infocenter.arm.com/.../index.jsp
"This is caused by an instruction such as PUSH {r0}^ where the ^ indicates access to user registers. The ARM ARM specifies that writeback to the base register is not available with this instruction. Instead, the base regsiter should be updated separately, e.g.: SUB sp, sp,#4 STMFD sp, {r0}^ See also A1085W"
thanks for the link.
