Hi, i looked at the CLKOUT pin using a scope expecting to see a square wave type of signal, it looks like a sine on sine signal. I am not sure if it is a board design problem or if it should look like this. Does any one know?
It is OK for clock signals w/ high enough fequency (10+ MHz), especially depending on oscillator circuit you use.
--- Nikolay.
In my previous post "oscillator circuit" stands for input clock of course but the same valid for output as in your case.
Yes, it is wave shapped for EMC reduction.
