I am problems with bank switching: I use: Keil Compiler, STR912FAW44X6 rev H and ULINK2. Bank 0: Main program (FMI not configured) Bank 1: Bootloader (FMI: NBBank 512K, 0x80000, BBank 32K 0x0). The RemapBank 1 is uncommented from 91x_fmi.h Hardware remap using CSX bit activated to boot always from bank 1.
I start from Bank 1, and jump to Bank 0 using the following function stored in RAM: FMI->BBSR = 0; //Size 32K FMI->NBBSR = 6; //Size 512K FMI->NBBADR = 0x0 >> 2 ; FMI->BBADR = 0x80000 >> 2; FMI->CR |= 0x18; Jump_To_Application = (pFunction) 0x00; Jump_To_Application();
The program gets blocked. If I press reset or power-off the program starts again from bank 1, but never jumps to bank 0.
Trick: I load a program on bank 0 with FMI BBank: 512K, 0x0, NBBank 32K, 0x80000 and then load again the same program on Bank 0 with the FMI not configured. In this case the jump from Bank 1 to 0 is done OK. If I press reset, the program starts again from Bank 1 and the jump is always done OK.
The problem is that when I disconnect the power, the program starts again from Bank 1 but gets blocked when jumping to 0. It seems that some register stored the first time I loaded the program on bank 0 with FMI, is mantained until the power is switched off. And when switching off, the FMI on bank 0 is not configured and this is why it crashes (not sure about that).
Please I need some help to resolve this problem and find the correct FMI configuration to switch between banks.
Thank you very much, Firin
