phyCORE-XC167 with XC167CI
Hallo
I work with a phyCORE-XC167 with XC167CI (16).
IÂ'generetead PWM (CAPCOM6),
so
I have the timer T12 Stopped
So that I can given the frequency for T12
I give the period
Then I set the Output CC60 and COUT60
Then i giving the Value to compared
And finally , I started the timer T12
//Programm
sbit P1L_0 = P1L^0 ; // declare portpin to use
sbit DP1L_0 = DP1L^0 ; // declare direction bit to use
sbit P1L_1 = P1L^1 ;
sbit DP1L_1 = DP1L^1 ;
void main (void) {
DP1L_0 = 1 ; //init Direction to output
DP1L_1 = 1 ; //init Direction to output
//PWM Konfiguration
CCU6_TCTR0 = 0x0010 ; // T12 ist gestoppt
CCU6_T12PR = 800; //Die Periode der Timer
CCU6_TCTR0 = 0x0009; //T12PRE=1 und T12CLK=001
CCU6_T12MSEL = 0x0003; //Compare output on pins COUT6x and CC6x.
CCU6_TCTR4 = 0x0002 ; // Start the Timer
while(1) // endlosschleife
CCU6_T12 = 400; // Count value to compared
but i have no reaction in the Output ?
Thanks in advance
Many thanks for your help
  • How is this different from this thread:
    http://www.keil.com/forum/docs/thread11844.asp
    And please, please please: Do check how to post source code! People do not like to read your code if it isn't posted in a readable format. And if people do not read your code, then people will obviously not be able to help you either.
  • Hallo
    There is no difference,
    I am sorry . !!
    Please show me, how I can send the code in a readable format ?
    i don t understand what i muss doing ?
    Thank you in advance
    my Code
    #include <XC167.h>
    /* special function register for XC161 */
    void main (void) {
    DP1L_0 = 1 ;
    DP1L_1 = 1 ;
    //PWM Konfiguration
    CCU6_TCTR0=0x0010 ;
    CCU6_T12PR = 800;
    while(1)
    CCU6_T12 = 400;
  • I think you may have some misunderstandings on how the CCU6 works. Perhaps reading the manual again along with looking at the values below will help you gain a better understanding.
    Enclosed is an example of a PWM (CC60 and COUT60) with a duty cycle of 50% along with dead time generation and where COUT60 is the complement of the CC60 output level.
    #include <XC167.h>
    #include <intrins.h>
    void main (void) {
      /* PWM Configuration */
      ALTSEL0P1L = 0x0003;
      _bfld_ (P1L, 0x03,0x03);
      _bfld_ (DP1L,0x03,0x03);
      CCU6_TCTR0   = 0x0009; /* T12 = fper/512 */
      CCU6_T12PR   = 800;    /* choose a period value */
      CCU6_CC60SR  = 400;    /* 50% duty cycle */
      CCU6_T12DTC  = 0x010F; /* enable dead time control for CC60/COUT60 */
      CCU6_T12MSEL = 0x0003; /* Compare output on COUT60 and CC60 */
      CCU6_MODCTR  = 0x0003; /* T12 modulates CC60, COUT60 */
      CCU6_PSLR    = 0x0002; /* passive level of COUT60 output is one */
      CCU6_TCTR4   = 0x0042; /* load period, duty cycle and start T12 */
      while(1)
  • First, thank you
    Ok, I will read The manul Again. And thanks for your help
    Nice week
  • Hello
    First, thank you for the answer. This code has not worked.
    With the debugger, I found the following problems.
    1: No Pwm on output.
    2, the frequency is not changed at 78KHz.
    3: CCU6_T12PR does not have the value of code! = 800
    but (CCU6_T12PR = 0x0000).
    4: CCU6_PSLR has not the value of code
    I can only change the frequency if I stop the timer T12?
    What about STE12 in CCU6_TCTR0?
    What about T12R in CCU6_TCTR0? To stop Timer T12
    What about T12RR in CCU6_TCTR4? T12 Stops Counting
    What about T12RS in CCU6_TCTR4? T12 Starts Counting
    What is T12STR in CCU6_TCTR4? T12 requesting the transfer Schadow
    //Code
    #include <XC167.h>
    void main (void) {
    while(1)
