Timer 2
I am using timer 0 for generating 20msec interrupts, and Timer 1 as a baud rate generator. Now, I require Timer 2 in my project. So, I had studied the pdf's of Phillips 89C52X2 and started writing code as described below. if I need timer 2 in auto-reload mode in up-counting timer style. I need to toggle test led every 1 sec, which is working fine using Timer 0. But, it is not working if I use Timer 2. I need a solution
Please advise.
##############  PART OF MY PROJECT CODE ###################
unsigned int volatile  time_keeper;
void serialInit(void)
        IE = 0;                  /* disable the interrupts */
        RI=0;                   //serial port receiver and trans meter is
        TI=0;
        T2CON = 0x04;
        T2MOD = 0x02;
        TH2 = 0XB8;     //load timer 2 for generating 20 msec delay
        TL2 = 0X00;
        ET2=1;                  //enable timer 2 interrupt
        RCAP2L = 0X00;
        RCAP2H = 0XB8;
        TR2=1;                  //run the timer 2
        EA=1;                   //enable global interrupt flag
void onTimerISR(void)interrupt 5 using 1
        EA  = 0;
        TR2 = 0;
        TH2 = 0xB8;
        TL2 = 0x00;
        TR2 = 1;
        time_keeper++;  //incrementing the timer on every
                                        //interruptso we can have delay in
                                        // multiples of 20msec
        if(!(time_keeper%50))
        test_led = ~test_led;   // test led toggling every 1 second
        ET2=1;
        EA=1;           //enable Interrupt
void main(void)
  time_keeper = 0;
  serialInit();
  demonTask();
