is this a bug or a feature?: as soon as GPIO5 is powered up (recover from reset and clock), pins 0 throught 7 except for 3 are in "high". Thus they cannot be used as inputs.
It does not make a difference to set clock manually or by startup file. Behaviour is the same.
I urgently need to use the pins as inputs. Any help is welcome!
Keil uVision3 with MCBSTR9 is used.
Cheers Nik
