The current project I am working uses RTX with TCPnet. The project uses TCP, UDP broadcast, unicast, and multicast. We bought and installed the RTL within the last 6 months. The multicast functions do not work! Here are some problems I have found: Domuntation: The udp_get_socket function is in the RL-TCPnet library. The prototype is defined in rtl.h. source http://www.keil.com/support/man/docs/rlarm/rlarm_udp_get_socket.htm The igmp_join function is in the RL-TCPnet library. The prototype is defined in rtl.h. source http://www.keil.com/support/man/docs/rlarm/rlarm_igmp_join.htm The igmp_leave function is in the RL-TCPnet library. The prototype is defined in rtl.h. source http://www.keil.com/support/man/docs/rlarm/rlarm_igmp_leave.htm None of these things are defined in the RTL.h file. Where are they, or do they exist? I am wating on KEIL to respond to my support request.
At this point I will answer my question here. Keil has contacted me and stated the RL_TCP does not have IGMP in the current build. Interesting?
The on-line manual has been already updated for the next upcoming release that will be available by end of next week.
Who in Keil did you contact?
His name was brian.
I am at home now and I do not know his last name. He sent me a link to the new lib today. It seems that that the lib that the our IT group installed out of the box was out of date. The Lib was updated and the code is testing great now...Many Thanks.
BW
