No Startup.s File at cortex-m3?
when I create a new Project in µVision for STM32F103RBT6 there is no startup code generated. When I select STR711 (my 2nd Board), µVision create some startup code. Why?
My next Problem is the incompatibility from some Examples, when I switch between RealView and Keil Compiler. Which Compiler should I use - which is the best?
Philipp
