Error with Vista
I may be posting an error which already is discussed and even fixed, but, alas, I couldn't find any discussion thru the search..
Well, I changed from an well working Win Xp for ARM7 GCC on keil to Vista, and the keil always throws out the following errors.
I tried googling and found some way too complex discussions (www.avrfreaks.net/index.php)and couldn't locate a solid fix. Any helps?
This is what the keil throws:-
C:\Cygnus\Arm-Tools\Bin\arm-uclibc-gcc.exe: *** heap allocated but not at 0x7A0000
1488294 [main] arm-uclibc-gcc 2208 sync_with_child: child 2116(0x120) died before initialization with status code 0x1
1563840 [main] arm-uclibc-gcc 2208 sync_with_child: *** child state waiting for longjmp
Thanks,
Vijay
