I have a question about using µVision and RedBoot. RedBoot loads an image via tftp to 0x80000, ther is RAM on my DEV-Board.
My problem is that I don't know how to tell the linker addresses. Can anyone help me in - what addresses do I have to insert where in the Options Menue? - how to set up a correct scatter file (do I need one? I think the basic controller setup is done by redboot...)
At least I want to compile source code that is _not_ executed after reset, the code will be started by redboot and so I don't need the whole controller setup.
Many thanks!
Greetings, Th. de Buhr
take a look to C:\Keil\ARM\Hlp\RVI.CHM - Linker Configuration.
