Slow, slow , slow TCPNet ...
I'm using a MCB2368 board with both RTX and TCP Net over ethernet.
I have a single tcp task that manages all my socket.
The other task is a FTP server connected to a SD memory card and communicates through mailbox and events mith the main tcp.
My chins dropped away (is it the good expression ? ) when I saw the speed : 6KB/s ....
Ok , so I removed the sd card reading and I had something like that when sending data over my socket :
sdbuf=_alloc_box(sdcardpool); //a dynamic allocated block
memset(sdbuf,1,1400); // fill the block with 0x01
// Send quite filled TCP frame 20times (20*1400=28000 bytes)
for (i=0;got<20;got++)
        SendFtpData(sdbuf,1400);
In SendFtpData() , I allocate the tcp buffer , send the frame, and wait for a ACK event from the main tcp task :
void SendFtpData(U8 *buf,U16 len)
        TcpFrame *frame;
        frame=_alloc_box (mpool);
        os_mut_wait(mutex_getbuf,0xFFFF);
        frame->message=tcp_get_buf(len);
        os_mut_release(mutex_getbuf);
        memcpy(frame->message,buf,len);
        frame->length=len;
        os_mbx_send(mailbox3,&frame,0xFFFF);
        os_evt_wait_or(EVT_FTP_DATA_ACK,0xFFFF);
        _free_box(mpool,frame);
So , with a simple memory block filled and sent 20 times I get only 6.3 KB/s ... So I can say that it's not the FAT/SD card stack that is slow.
In this case why Tcpnet is so slow ?
Is it possible to manage blocks of data and not each tcp frame ?
Thanks in advance.
