Hi, i am currently working on the project on 8051. The software that i am using is keil uVision3.
i am writing a delay loop for my LED but there is a syntax error in the code. Below is the code:
(1) void delay_time(void) (2) { (3) unsigned int a,b; (4) for(a=0, a<100, a++) (5) for(b=0, b<100, b++); (6) }
and the syntax error is:
line(4): error C141: syntax error near ')' line(5): error C141: syntax error near ')'
Can anyone help me on this? Any help is greatly appreciated!
It should be like this: (4) for(a=0; a<100; a++) (5) for(b=0; b<100; b++);
use ';' instead of ','! in the for loop.
use assembler.
Your delay loop does not have any side effects, and therefore it is fair game for the optimizer to remove completely.
Your delay loop does not have any side effects, and therefore it is fair game for the optimizer to remove completely. just one more argument for using assembler.
the worst any '51 programmer can suffer from is assemberofobia.
In the case of a very simple, first program where all that matters is the LED being on for a while and off for a while - a 'for' loop delay in 'C' is (probably) adequate providing it doesn't get removed by the optimiser, as others have already noted.
However for any other use you should definitely use assembler for a software delay
See: www.8052.com/.../read.phtml for the reason why, and how to do it.
