hi friends,
i wanted to increase the port pins with the help of 8255 for 89c51 mcu(atmel)
does any one have the c codes that can work with keil uvision (or c51 compiler). i simply require a sample program with which if i push a switch on any port pin of 89c51 and i can lit an LED DIODE connected on a single 8255 port pins.
your help can make a great fevour for me.
I wanted to increase the port pins with the help of 8255 for 89c51 mcu(atmel)
if someone has kept code from ages ago, possibly. The days when the 8255 was used, the king of diamonds were still a jack.
Why do you want to use such an antique.
If this is a school assignment, ask for your monet back and RUN. Then find a place that teaches current technology.
"i simply require a sample program with which if i push a switch on any port pin of 89c51 and i can lit an LED DIODE connected on a single 8255 port pins."
To provide that, we would at least need to know how your 8255 is connected to the 89c51: Is it memory mapped? Is it just connected to port pins - if so, how?
Have you read the Datasheet for the 8255?
See also: http://www.keil.com/forum/docs/thread11507.asp
Actually, if it's a school assignment you should be doing it yourself and not cheating by asking for the answers here!
And if it is a school assignment, you should do it just for the experience, but realise that there are better ways to achieve it with modern devices...
A number of people have made questions about the 8255 as port expansion. Must be a school using it somewhere...
