When attempting to create the MON51.hex files per intstructions all appears to run properly, however the hex file created is of 0kb. When an attempt to download file to hardware (cc2430) is made the programmer software indicates "could not open hex file" and pauses. Other hex files in the same directory are opened and loaded as they should....am I missing something here....?
Are you using an EVAL version. With an Eval Version the Monitor cannot be configured.
