Hi all, I am porting RTX on LH7A404. Now SWI and Clock interrupt worked well. I used the example1 as test program. The code is below.
As you can see in the code, there are two tasks for testing basic function of the OS. I use counter to check the state of the task. "task1cnt" is used to check task1 state and "task2cnt" to task2. When I run the program. I always get the result, task1cnt=0 task2cnt=1. Os is always in the idle task.
I tried to trace the condition more deeply. I found that context_switch always select task2 as next run task. But when task2 occupies the OS, it resumes the previous session and executed the os_block. At this time, os did the next context-switch immediately and task2 almost did nothing. So I think this is why my test program is blocked.
Is there anyone help me? how can I do? Give me some hints about this problem.
#include "RTL.h" OS_TID id1, id2; void task1 (void) __task; void task2 (void) __task; void task1 (void) __task { // EnableARMIRQ(); /* Obtain own system task identification number */ static int task1cnt=0; id1 = os_tsk_self (); /* Assign system identification number of task2 to id2 */ id2 = os_tsk_create (task2, 1); for (;;) { /* do-this */ /* Indicate to task2 completion of do-this */ os_evt_set (0x0004, id2); /* Wait for completion of do-that (0xffff means no time-out)*/ os_evt_wait_or (0x0004, 0xffff); task1cnt++; /* Wait now for 50 ms */ os_dly_wait (5); } } void task2 (void) __task { static int task2cnt=0; for (;;) { /* Wait for completion of do-this (0xffff means no time-out) */ os_evt_wait_or (0x0004, 0xffff); /* do-that */ task2cnt++; /* Pause for 20 ms until signaling event to task1 */ os_dly_wait (2); /* Indicate to task1 completion of do-that */ os_evt_set (0x0004, id1); } } int main (void) { os_sys_init (task1); }
