Why does the programm always run in the supervisor mode if I use the simulator? If I use the Ulink2 to debug then the programm runs in user mode.
Moreover I don't understand why the programm don't see my variable int i=0; at the local watch window??? very strange... the whole code is only
int main (void) { int i=0; i++; while(1); }
I use the evaluation version of the db_arm version.
best regards Gerd
thanks for your answer....
If you have any optimizations turned on,
I'm new to keil products - but under options for target > C/C++ I use Optimization (Level0 (00).
Now I use volatile int but nothing changed - I'm not able to view the variable in the watch window...
BTW could you tell me how I can change in the simulator to the user mode? I mean there are two registers CPRS (something like that) but where do I have to install this information? Or is there a way to include the startup-code bevor enter the main.c routine?
