Is this code interrupt safe?
Hi all,
I check the assembly and I think that the call to
interrupt_safe_assign_ulong
(see below) is indeed interrupt safe but I am not sure (I am refering to the use of the static variable 's_long' as a parameter). Can you help me?
Thanks in advance
static unsigned long s_long ;
void store_and_disable_interrupts(unsigned short *a_interrupts)
        *a_interrupts = IEN ;
        IEN = 0 ;
void restore_interrupts(unsigned short a_interrupts)
        IEN = a_interrupts ;
void interrupt_safe_assign_ulong(unsigned long *a_target, const unsigned long *a_source)
        unsigned short  l_interrupts ;
        store_and_disable_interrupts(&l_interrupts) ;
        *a_target = *a_source ;
        restore_interrupts(l_interrupts) ;
interrupt_safe_assign_ulong(&l_long, &s_long) ;
