I am using an AT89C53-24 microcontroller with a 12.000 MHz crystal. My program uses hardware timer (T1-Mode 1, interrupts enabled) to provide a 20 mSec heartbeat, and hardware timer (T0-Mode 1, interrupts not enabled) to provide delays (at a 1 mSec rate). According to the performance analyzer, the measured delay for a 500 mSec delay request using T0 is on the order of 500.62 mSec.
When I observe this delay running on the actual hardware (applying an 7-seg LED count, by eye only) it seems more like the order of 200 mSec. I changed the delay to 1000 mSec, and the performance analyzer gave 1.0019 Seconds, but there is no perceived change in the rate on the actual hardware. I have checked:
The CPU frequency matches the target option frequency in the simulator. The CPU selected as the target matches the CPU used in the hardware. The CPU device selected in the programmer matches the CPU to be programmed. The behavior is the same independent of the interrupt status for timer 1
I could not find in the simulator literature any notes concerning the relationship between the simulated and actual performance. Is there a link between the two timers? As one is "firing" at 20 mSec (under interrupt) I could see a slight deviation 1/20th of the time to the 1 mSec timer based loop, but I thought they were hardware driven and as such completely independent. Any ideas? Have I missed some fundamental concept about timers on the 8051 family?
Any help would be appreciated.
Please let me know the your timer value calculation
The simulator doesn't simulate real time; it just simulates to cycles - you can convert that to time from knowing the clock frequency.
An 8051 simulation on a decent PC will generally run faster than real time!
For the 1ms timer, the load value is: 0xfc2f 65536 - (OSC_FREQ/CLK_PER_INS * 1/1020) For the 20ms timer, the load value is: 0xb368 65536 - (OSC_FREQ/CLK_PER_INS * 20/1020)
The value 1020 accounts for call overhead (as opposed to just 1000) The actual value for 1ms was adjusted using the simulator's performance value as a guide.
I wonder where this information comes from. Last time I looked, the simulator in uVision did simulate real time --- no need to do any conversions, since simulation time is displayed right there in the registers window.
The one thing it does not do, is keep up with real time. I.e. simulated seconds can be longer or shorter than actual seconds. But that doesn't matter, since all the simulated peripherals are kept in synch to the common simulated time.
Last time I looked, the simulator in uVision did simulate real time --- no need to do any conversions, since simulation time is displayed right there in the registers window. my be true, may not be. there are a plethora of devices ( 1, 2, 4 and 6 clockers) that a) uses fewer clocks and b) does not adhere to "the bible' re no of clocks for a given instruction.
"The one thing it does not do, is keep up with real time"
That's what I meant by not simulating real time. Sorry if it wasn't clear.
So what? There's really no problem to tune the simulator accordingly. Compared to the work involved in simulating all the builting peripherals, those are peanuts. Overall, the simulator almost certainly gives you more precise measurements of code than any other method short of counting clocks by hand.
