While opening a C166 project I got this error:
uVision3 â€" Path for Toolset undefined ‘C:\Keil\Tools.INI’ does not contain a tool path You have selected a device where no toolchain has been installed.
Who knows the reasons?
Is the C166 toolchain correctly installed on your computer? Just re-install it. This will solve the problem then.
"Who knows the reasons?"
Isn't the reason clear from the message:
'C:\Keil\Tools.INI' does not contain a tool path
Have you looked in 'C:\Keil\Tools.INI' ?
Does it contain a tool path ?
If it does, is it correct ?
If it doesn't - well, the answer is obvious!
