Just installed Keil uVision 3.05, including the Arm7 compiler. First startup shows a segmentation fault (null pointer reference) on the ArmCC.exe compiler. I checked its location (C:\Keil\ARM\BIN30) and tried to run it from the command line, same result.
I saw elsewhere on this forum updates and patches, but when I install these, I get a no license for version >= 3.0 error. I then also tried the 2.2 versions but get a no licence for version >= 2.2 error.
Can anyone help ?
Yesterday I downloaded version 3.11 and installed it this morning. I can now successfully open an existing project without the compiler crashing, did exactly the same actions as the 3.05 version would crash. Somehow a bug in the compiler has been solved between 3.05 and 3.11 I guess. Question remains if we have to upgrade all existing licenses or try to find the problem on 3.05 ?
Kind Regards, Bart
the problem only exists in the Eval Mode. See: http://www.keil.com/support/docs/3349.htm
Just before this latest answer I received a licence key from a free licence package from my manager and the problem seems to have been gone. These kind of errors however give me a very bad feeling about the stability of a software package, but I now have confidence that it will all work fine !
Thanks, Bart
