I use the same programme and different Rom size, 64K and 96K. Then I fire them to Philips P89C669 separate. Then I use them and some functions don't work well using 96K one. Eg. some data is not correct. I want to know what difference between using 64K translate and using 96K. Thank you~
http://www.keil.com/forum/docs/thread10950.asp#msg52887
You need to present details about your problem when you expect answers.
