I'm working with some project right now, I need some example about how to run part of code from RAM. I found the code in IAR version, I wonder if someone can help me to translate it into KeilC version.
void runFunctionFromRam(void (*func) (void), unsigned char *ramPtn, unsigned char length) { unsigned char code *codePtn; unsigned char i; // void *f (void * ptr);
// Save start address for function in RAM void *f (void) = (void*)(int)ramPtn;
// get pointer to function in code codePtn = (unsigned char code *)(int)func;
// Copy function from code to RAM for(i = 0; i < length; i++) { ramPtn[i] = codePtn[i]; } EA = 0;
// Enable unified code model MEMCTR |= 0x40;
// Run function from RAM
// Disable unified code model MEMCTR &= ~0x40; EA = 1; }
I'm having problem with these line : void *f (void) = (void*)(int)ramPtn; and (*f)(void);
The compiler won't let me pass with these line.
What chip are you using ? It needs to deviate quite a bit from a "standard" '51 to able to run code from some type of RAM - in a normal '51 code memory consists of (EEP)ROM.
What error messages do you get ?
The 8051 itself knows nothing at all about RAM or (EEP)ROM - all it knows is its address spaces - CODE, XDATA, etc.
The 8051 architecture has no capability to fetch instructions from any address space other than CODE - it neither knows nor cares whether that address space is populated with RAM, ROM, FRAM, Magnetic Core, or anything else...
See my post "RE: Common over-simplification" here: http://www.keil.com/forum/docs/thread10818.asp
And the linked "8051/8052 Memory Architecture" in this thread: http://www.keil.com/forum/docs/thread10634.asp
www.danlhenry.com/.../keil_code.png
Be sure to carefully study all the literature (knowledgebase articles & application notes) about Function pointers in C51...!!
This is not trivial!
